How can we setup setup only a records for a website not whole name server and how to use aa panel as dimk and dns server proper configuration
    is_ishan_singla
    Hi, I suggest you describe the problem in detail.
    dimk is only used by the mail server
    It is recommended to use a third-party dns server. Currently, there are known problems with the dns manager. Some records will not be propagated.
    OK I wants to make my own dns servers can you help me out and wants to setup and to setup dns redirect ip for other server vps to deploy node websites
    I am just trying to use kubernates ci/cd with that can we have a meet
      I want to automate the installation of the panel and applications using python, since I need to install it on more than one server, can you tell me how this can be done. maybe you have ready-made installation commands, I would be very grateful
      I install the panel itself via ssh, but I can’t figure out how to install the applications, can I install them without going into the panel?
        aaPanel_Kern but I wants it at any cost and me is into adding kubernates support and GitHub support for ci/cp pipelines setup as a contribution can me help me out please
