• Support
  • ext-zip is missing from your system. Install or enable PHP's zip extension.
This is the updated command
php_version=81
echo /www/server/php/${php_version}/src/ext/zip
cd /www/server/php/${php_version}/src/ext/zip
/www/server/php/${php_version}/bin/phpize
./configure --with-php-config=/www/server/php/${php_version}/bin/php-config
make && make install
if [ "${php_version}" == "73" ];then
	extFile="/www/server/php/73/lib/php/extensions/no-debug-non-zts-20180731/zip.so"
elif [ "${php_version}" == "74" ]; then
	extFile="/www/server/php/74/lib/php/extensions/no-debug-non-zts-20190902/zip.so"
elif [ "${php_version}" == "80" ]; then
	extFile="/www/server/php/80/lib/php/extensions/no-debug-non-zts-20200930/zip.so"
elif [ "${php_version}" == "81" ]; then
	extFile="/www/server/php/81/lib/php/extensions/no-debug-non-zts-20210902/zip.so"
fi
if [ -f "${extFile}" ];then
	echo "extension = zip.so" >> ${php_setup_path}/etc/php.ini
fi
echo -e "extension = " ${extFile} >> /www/server/php/${php_version}/etc/php.ini
echo -e "extension = " ${extFile} >> /www/server/php/${php_version}/etc/php-cli.ini
/etc/init.d/php-fpm-${php_version} reload
But I have a directory like /www/server/php/81/
    buzz4rd
    el=$(cat /etc/redhat-release|grep -iE 'CentOS|Red Hat'|grep -Eo '([0-9]+\.)+[0-9]+'|grep -Eo '^[0-9]')
    download_Url="http://node.aapanel.com"
    mkdir /tmp/libzip
    cd /tmp/libzip
    wget -O libzip5-1.5.2.rpm ${download_Url}/rpm/remi/${el}/libzip5-1.5.2.rpm
    wget -O libzip5-devel-1.5.2.rpm ${download_Url}/rpm/remi/${el}/libzip5-devel-1.5.2.rpm
    wget -O libzip5-tools-1.5.2.rpm ${download_Url}/rpm/remi/${el}/libzip5-tools-1.5.2.rpm
    yum install * -y
    cd ..
    rm -rf libzip
      buzz4rd
      Post link:
      No post link will not be able to know which user's information is
        aaPanel_Kern Thanks for your support. Unfortunately, it does not have snapshot backup. I have to take backup manually. So, I will share the info after taking backups.
        a year later
        do you have any estimated date to fix this issues still now this bug is not fixed
