I am SUPER confused why everybody here is so fast to say "china want to kill us" ......
chill bro
chill bro
KrzysztofMaciejewski please
can you tell me the ip class so i can block on cloudflare firewall and fail2ban? thank you
CQT
they are tying to hack by checking bad configuration as its opensource they can read all files related to panel and trying to scan files related to aapanel to see loopholes to grab into server.
hope aapnel is more secure system to block this spammers and attackers
@aaPanel_Jose
if possible add alert system via email for any files changes and to lock files for any changes with a button on panel under domains enable and disable
KrzysztofMaciejewski Well, I for one am not saying that at all, but to me, security is pretty serious and any time there is a question, it should be taken seriously and looked into. For you, maybe you don't care too much I guess.
wow probably forgot that some cannot read. I wrote that the tracking code is used to later access the IPs it receives and that is from the developer's own network and which is bt.cn (BaoTa), there the scripts are hosted and the IPs are saved there, which aaPanel installed. After a while, the stored IPs are attacked. At the moment we have the pleasure of being attacked by the BaoTa network. aaPanel or aaPanel_Jose has to consider here whether the tracking code has to be, since this gives conclusions about your IPs. I have never said that the aaPanel itself is the cause, indirectly already there is the possibility to stretch the IPs. And this has to be clarified seriously, until then we will convert all servers with aaPanel!
MarcusVinicius the entire network of Baidu is used to carry out hacking attacks all over the world, we have already reported this to RIPE and ICANN are going to get to the bottom of it, let's see what possibilities there are, since he attacks a lot from the region, and this region too is responsible for a number of IP counterfeits and IP thefts. as long as the tracking of IPs remains, we will install another ACP.
in my opinion tracking is not problem here as cpanel and plesk have full track of your server IP and domain for licence verification but they have good security and privacy, now weather aapanel tracker how secure is it how details are getting leaked or exposed to hackers that need to find by aapanel team to track
@CQT
if you can provide more info to all users about your experience how to got this info and logs where to checked etc all others can check and provide feedback.
@aaPanel_Jose if he can add geo base blocking under firewall it will great
Since I myself have only limited knowledge of Py, an employee of mine will take a closer look at the script, we will document every part and also put it up for discussion here. Again we do not want to make aaPanel insinuations, it is only up to Baota and its tracking or reloading of files of unsafe origin. I appreciate the work of aaPanel and the team, I know how difficult it is for them. But I also value data protection and refuse to expose my customers to risk.
CQT great news!
Security is important. Thanks for your professional approach.
aaPanel_Jose awesome!!! thanks for great service!!! you're best!
CQT aaPanel_Jose JAY
the security of our servers is of utmost importance! I chose to migrate from webmin to aaPanel because the panel apparently has a lot of security options! I'm sure that our aaPanel, with the help of great programmers, we will have no problems!
These are just Postfix attacks from today and everything is traceable to China via proxies! It is no longer nice
Jun 25 00:58:10 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.18]
Jun 25 00:58:11 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:13 serv01 postfix/smtpd[29491]: connect from unknown[185.143.72.16]
Jun 25 00:58:14 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.2]
Jun 25 00:58:14 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.25]
Jun 25 00:58:19 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:20 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:20 serv01 postfix/smtpd[29491]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:20 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:21 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:22 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:22 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:23 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:24 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.81]
Jun 25 00:58:25 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 00:58:31 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:31 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:31 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.34]
Jun 25 00:58:31 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:31 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.2]
Jun 25 00:58:31 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:35 serv01 postfix/smtps/smtpd[29825]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:35 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.25]
Jun 25 00:58:38 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:39 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:39 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:39 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.18]
Jun 25 00:58:39 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:40 serv01 postfix/smtpd[29932]: connect from unknown[185.143.75.81]
Jun 25 00:58:43 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:44 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:45 serv01 postfix/smtps/smtpd[29825]: lost connection after AUTH from unknown[212.70.149.66]
Jun 25 00:58:45 serv01 postfix/smtps/smtpd[29825]: disconnect from unknown[212.70.149.66] ehlo=1 auth=0/1 rset=1 commands=2/3
Jun 25 00:58:46 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:46 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:51 serv01 postfix/smtpd[29932]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:58:51 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:58:52 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.18]
Jun 25 00:58:53 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.2]
Jun 25 00:58:53 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.34]
Jun 25 00:58:53 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 00:58:54 serv01 clamd[1879]: SelfCheck: Database status OK.
Jun 25 00:59:00 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:00 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:00 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:01 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:01 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:02 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:03 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:03 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:09 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.25]
Jun 25 00:59:10 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.2]
Jun 25 00:59:15 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.81]
Jun 25 00:59:16 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 00:59:16 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:17 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:17 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:17 serv01 postfix/smtps/smtpd[27815]: connect from unknown[212.70.149.66]
Jun 25 00:59:18 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:19 serv01 postfix/smtpd[29491]: connect from unknown[185.143.72.16]
Jun 25 00:59:21 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.18]
Jun 25 00:59:22 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:22 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:23 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:24 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:25 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.34]
Jun 25 00:59:26 serv01 postfix/smtpd[29491]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:27 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:27 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:27 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:30 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.25]
Jun 25 00:59:31 serv01 postfix/smtpd[29491]: connect from unknown[185.143.75.81]
Jun 25 00:59:31 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.2]
Jun 25 00:59:34 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:34 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.18]
Jun 25 00:59:34 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:38 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:38 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:38 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:39 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:42 serv01 postfix/smtpd[29491]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:43 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:43 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.16]
Jun 25 00:59:45 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:45 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 00:59:45 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:48 serv01 postfix/smtpd[29491]: connect from unknown[185.143.72.34]
Jun 25 00:59:48 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.2]
Jun 25 00:59:50 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:51 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:52 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:52 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:53 serv01 postfix/smtps/smtpd[29825]: connect from unknown[212.70.149.66]
Jun 25 00:59:55 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:55 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 00:59:56 serv01 postfix/smtpd[29491]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 00:59:56 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:04 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.25]
Jun 25 01:00:04 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.18]
Jun 25 01:00:06 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.81]
Jun 25 01:00:08 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 01:00:10 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.2]
Jun 25 01:00:11 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:12 serv01 postfix/smtpd[30019]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:12 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:12 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:13 serv01 postfix/smtps/smtpd[27815]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:15 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:15 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:17 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:17 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.18]
Jun 25 01:00:17 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:20 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.34]
Jun 25 01:00:23 serv01 postfix/smtpd[29491]: connect from unknown[185.143.75.81]
Jun 25 01:00:24 serv01 postfix/smtps/smtpd[27815]: lost connection after AUTH from unknown[212.70.149.66]
Jun 25 01:00:24 serv01 postfix/smtps/smtpd[27815]: disconnect from unknown[212.70.149.66] ehlo=1 auth=0/1 rset=1 commands=2/3
Jun 25 01:00:25 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:25 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.25]
Jun 25 01:00:25 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:27 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:27 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:27 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.2]
Jun 25 01:00:28 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:28 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:30 serv01 postfix/smtpd[29491]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:30 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:33 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:34 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:36 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:36 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.153]
Jun 25 01:00:36 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:43 serv01 postfix/smtpd[29491]: connect from unknown[185.143.72.34]
Jun 25 01:00:43 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:44 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:46 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.18]
Jun 25 01:00:48 serv01 postfix/smtps/smtpd[29825]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:48 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.16]
Jun 25 01:00:49 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.2]
Jun 25 01:00:50 serv01 postfix/smtpd[29491]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:51 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:53 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:53 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:53 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:53 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:56 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:00:56 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:00:58 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.81]
Jun 25 01:00:58 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.25]
Jun 25 01:00:58 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 01:00:58 serv01 postfix/smtps/smtpd[29825]: lost connection after AUTH from unknown[212.70.149.66]
Jun 25 01:00:58 serv01 postfix/smtps/smtpd[29825]: disconnect from unknown[212.70.149.66] ehlo=1 auth=0/1 rset=1 commands=2/3
Jun 25 01:00:59 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.18]
Jun 25 01:01:04 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:04 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:05 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:05 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:05 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:06 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:06 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.2]
Jun 25 01:01:09 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:09 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:13 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.16]
Jun 25 01:01:13 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:14 serv01 postfix/smtpd[29491]: connect from unknown[185.143.75.81]
Jun 25 01:01:14 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:15 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.34]
Jun 25 01:01:19 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:19 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.25]
Jun 25 01:01:20 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:23 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:24 serv01 postfix/smtpd[29491]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:24 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:24 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:27 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:27 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 01:01:28 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:28 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.2]
Jun 25 01:01:29 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.18]
Jun 25 01:01:34 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:34 serv01 postfix/smtps/smtpd[27815]: connect from unknown[212.70.149.66]
Jun 25 01:01:34 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:35 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:36 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:36 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:37 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:38 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.34]
Jun 25 01:01:42 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.18]
Jun 25 01:01:45 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.2]
Jun 25 01:01:45 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:46 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:49 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.81]
Jun 25 01:01:49 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.153]
Jun 25 01:01:52 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:53 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:53 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:53 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:53 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.25]
Jun 25 01:01:57 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:57 serv01 postfix/smtpd[30019]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:01:57 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:01:57 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:01 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:01 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:05 serv01 postfix/smtpd[29932]: connect from unknown[185.143.75.81]
Jun 25 01:02:07 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.2]
Jun 25 01:02:10 serv01 postfix/smtpd[29491]: connect from unknown[185.143.72.34]
Jun 25 01:02:10 serv01 postfix/smtps/smtpd[29825]: connect from unknown[212.70.149.66]
Jun 25 01:02:11 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.18]
Jun 25 01:02:14 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:14 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:14 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.25]
Jun 25 01:02:16 serv01 postfix/smtpd[29932]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:16 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:17 serv01 postfix/smtpd[29491]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:18 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:18 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:18 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.16]
Jun 25 01:02:18 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:18 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:02:22 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:23 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:24 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.2]
Jun 25 01:02:24 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.18]
Jun 25 01:02:25 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:25 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:25 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:26 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:31 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:31 serv01 postfix/smtps/smtpd[27815]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:31 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:32 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.34]
Jun 25 01:02:35 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:36 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:39 serv01 postfix/smtps/smtpd[27815]: lost connection after AUTH from unknown[212.70.149.66]
Jun 25 01:02:39 serv01 postfix/smtps/smtpd[27815]: disconnect from unknown[212.70.149.66] ehlo=1 auth=0/1 rset=1 commands=2/3
Jun 25 01:02:40 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.81]
Jun 25 01:02:40 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:40 serv01 postfix/smtpd[29932]: connect from unknown[185.143.75.153]
Jun 25 01:02:41 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:42 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.16]
Jun 25 01:02:45 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.2]
Jun 25 01:02:47 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:47 serv01 postfix/smtpd[29932]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:47 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:47 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:47 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.25]
Jun 25 01:02:49 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:49 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:50 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:50 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:02:54 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.18]
Jun 25 01:02:55 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.81]
Jun 25 01:02:56 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:02:56 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:01 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:02 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:02 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.2]
Jun 25 01:03:05 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.34]
Jun 25 01:03:06 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:06 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:07 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.18]
Jun 25 01:03:09 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:03:09 serv01 postfix/smtpd[29491]: connect from unknown[185.143.72.25]
Jun 25 01:03:09 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:10 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:12 serv01 postfix/smtps/smtpd[29825]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:13 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:14 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:16 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:16 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:17 serv01 postfix/smtpd[29491]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:17 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:18 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:18 serv01 postfix/smtps/smtpd[29825]: lost connection after AUTH from unknown[212.70.149.66]
Jun 25 01:03:18 serv01 postfix/smtps/smtpd[29825]: disconnect from unknown[212.70.149.66] ehlo=1 auth=0/1 rset=1 commands=2/3
Jun 25 01:03:18 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:24 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.2]
Jun 25 01:03:27 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.34]
Jun 25 01:03:30 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:30 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:30 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.81]
Jun 25 01:03:30 serv01 postfix/smtpd[29750]: connect from unknown[185.143.75.153]
Jun 25 01:03:34 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:34 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:36 serv01 postfix/smtpd[29491]: connect from unknown[212.70.149.18]
Jun 25 01:03:37 serv01 postfix/smtpd[29750]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:37 serv01 postfix/smtpd[30019]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:37 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:37 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:41 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.2]
Jun 25 01:03:42 serv01 postfix/smtpd[29491]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:42 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.25]
Jun 25 01:03:42 serv01 postfix/smtpd[29491]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:45 serv01 postfix/smtpd[29932]: connect from unknown[185.143.75.81]
Jun 25 01:03:47 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.16]
Jun 25 01:03:48 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:49 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:49 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.18]
Jun 25 01:03:50 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:51 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:51 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:51 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:52 serv01 postfix/smtps/smtpd[27815]: connect from unknown[212.70.149.66]
Jun 25 01:03:55 serv01 postfix/smtpd[29932]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:55 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:03:59 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:03:59 serv01 postfix/smtpd[29491]: connect from unknown[185.143.75.153]
Jun 25 01:03:59 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.34]
Jun 25 01:03:59 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:02 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.2]
Jun 25 01:04:03 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.25]
Jun 25 01:04:06 serv01 postfix/smtpd[29491]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:06 serv01 postfix/smtpd[29491]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:09 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:10 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:11 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:11 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.16]
Jun 25 01:04:12 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:16 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:17 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:17 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:18 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:19 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.18]
Jun 25 01:04:19 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.2]
Jun 25 01:04:20 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.81]
Jun 25 01:04:21 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:04:22 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.34]
Jun 25 01:04:25 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:25 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:26 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:26 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:27 serv01 postfix/smtpd[30019]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:27 serv01 postfix/smtps/smtpd[29825]: connect from unknown[212.70.149.66]
Jun 25 01:04:27 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:28 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:28 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:32 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.18]
Jun 25 01:04:33 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:34 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:37 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.25]
Jun 25 01:04:38 serv01 postfix/smtpd[29932]: connect from unknown[185.143.75.81]
Jun 25 01:04:41 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.2]
Jun 25 01:04:41 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:41 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:44 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:44 serv01 postfix/smtpd[29932]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:44 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:44 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:46 serv01 postfix/smtps/smtpd[27815]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:48 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:48 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:50 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.153]
Jun 25 01:04:54 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.34]
Jun 25 01:04:56 serv01 postfix/smtps/smtpd[27815]: lost connection after AUTH from unknown[212.70.149.66]
Jun 25 01:04:56 serv01 postfix/smtps/smtpd[27815]: disconnect from unknown[212.70.149.66] ehlo=1 auth=0/1 rset=1 commands=2/3
Jun 25 01:04:57 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:04:58 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:04:58 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.2]
Jun 25 01:04:58 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.25]
Jun 25 01:04:58 serv01 postfix/smtps/smtpd[29825]: lost connection after RSET from unknown[212.70.149.66]
Jun 25 01:04:58 serv01 postfix/smtps/smtpd[29825]: disconnect from unknown[212.70.149.66] ehlo=1 rset=1 commands=2
Jun 25 01:05:01 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:01 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.18]
Jun 25 01:05:02 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:05 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:06 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:06 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:06 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:07 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:07 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:11 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.81]
Jun 25 01:05:12 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:05:14 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.18]
Jun 25 01:05:16 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.16]
Jun 25 01:05:16 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.34]
Jun 25 01:05:18 serv01 postfix/smtpd[30019]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:18 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:18 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:18 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:19 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.2]
Jun 25 01:05:23 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:23 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:25 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:25 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:25 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:25 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:26 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:26 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:27 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.81]
Jun 25 01:05:32 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.25]
Jun 25 01:05:36 serv01 postfix/smtpd[29950]: connect from unknown[212.70.149.2]
Jun 25 01:05:37 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:37 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:39 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:39 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:40 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.16]
Jun 25 01:05:40 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:05:43 serv01 postfix/smtpd[29950]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:43 serv01 postfix/smtpd[29950]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:44 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:44 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.18]
Jun 25 01:05:44 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:47 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:47 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:49 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.34]
Jun 25 01:05:50 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:51 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:53 serv01 postfix/smtpd[29999]: connect from unknown[185.143.72.25]
Jun 25 01:05:57 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:05:57 serv01 postfix/smtpd[29932]: connect from unknown[212.70.149.18]
Jun 25 01:05:57 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:05:58 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.2]
Jun 25 01:06:01 serv01 postfix/smtpd[29999]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:02 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:02 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.81]
Jun 25 01:06:02 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:06:05 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:06 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:08 serv01 postfix/smtpd[29932]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:08 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:08 serv01 postfix/smtpd[29932]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:08 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:09 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:09 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:09 serv01 postfix/smtps/smtpd[27815]: connect from unknown[212.70.149.66]
Jun 25 01:06:15 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.2]
Jun 25 01:06:15 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.34]
Jun 25 01:06:17 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.81]
Jun 25 01:06:22 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:22 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:23 serv01 postfix/smtpd[29950]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:24 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:26 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.18]
Jun 25 01:06:27 serv01 postfix/smtpd[29750]: connect from unknown[185.143.72.25]
Jun 25 01:06:27 serv01 postfix/smtpd[30019]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:28 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:31 serv01 postfix/smtpd[29932]: connect from unknown[185.143.75.153]
Jun 25 01:06:33 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:33 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:35 serv01 postfix/smtpd[29750]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:35 serv01 postfix/smtpd[29750]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:36 serv01 postfix/smtpd[30019]: connect from unknown[212.70.149.2]
Jun 25 01:06:37 serv01 postfix/smtpd[29932]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:37 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:39 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.18]
Jun 25 01:06:42 serv01 postfix/smtpd[30019]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:42 serv01 postfix/smtpd[30019]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:45 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.34]
Jun 25 01:06:45 serv01 postfix/smtps/smtpd[30221]: connect from unknown[212.70.149.66]
Jun 25 01:06:47 serv01 postfix/smtpd[30019]: connect from unknown[185.143.72.16]
Jun 25 01:06:49 serv01 postfix/smtpd[29999]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:49 serv01 postfix/smtpd[29999]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:50 serv01 dovecot: master: Warning: Killed with signal 15 (by pid=30225 uid=0 code=kill)
Jun 25 01:06:51 serv01 dovecot: auth: Error: auth worker: Aborted PASSV request for leonid@vsecserver.de: Worker process died unexpectedly
Jun 25 01:06:51 serv01 dovecot: anvil: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Jun 25 01:06:51 serv01 dovecot: log(1317): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Jun 25 01:06:51 serv01 dovecot: log(1317): Warning: Shutting down logging for 'auth: ' with 1 clients
Jun 25 01:06:52 serv01 postfix/smtpd[29950]: connect from unknown[185.143.75.81]
Jun 25 01:06:53 serv01 postfix/smtpd[29999]: connect from unknown[185.143.75.153]
Jun 25 01:06:53 serv01 postfix/smtpd[29750]: connect from unknown[212.70.149.2]
Jun 25 01:06:56 serv01 postfix/smtpd[29999]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: Connection lost to authentication server
Jun 25 01:06:56 serv01 postfix/smtpd[29932]: warning: unknown[185.143.72.34]: SASL LOGIN authentication failed: Connection lost to authentication server
Jun 25 01:06:56 serv01 postfix/smtpd[29950]: warning: unknown[185.143.75.81]: SASL LOGIN authentication failed: Connection lost to authentication server
Jun 25 01:06:56 serv01 postfix/smtpd[30019]: warning: unknown[185.143.72.16]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:06:56 serv01 postfix/smtps/smtpd[27815]: warning: unknown[212.70.149.66]: SASL LOGIN authentication failed: Connection lost to authentication server
Jun 25 01:06:56 serv01 postfix/smtpd[29750]: warning: SASL: Connect to private/auth failed: Connection refused
Jun 25 01:06:56 serv01 postfix/smtpd[29750]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed:
Jun 25 01:06:56 serv01 postfix/smtpd[29950]: disconnect from unknown[185.143.75.81] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:56 serv01 dovecot: master: Dovecot v2.3.10 (0da0eff44) starting up for imap, pop3, lmtp (core dumps disabled)
Jun 25 01:06:56 serv01 postfix/smtpd[29999]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:57 serv01 postfix/smtpd[29932]: disconnect from unknown[185.143.72.34] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:57 serv01 postfix/smtpd[30019]: disconnect from unknown[185.143.72.16] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:06:57 serv01 postfix/smtpd[29750]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:07:06 serv01 postfix/smtpd[29950]: connect from unknown[185.143.72.34]
Jun 25 01:07:06 serv01 opendkim[1291]: OpenDKIM Filter: mi_stop=1
Jun 25 01:07:06 serv01 opendkim[1291]: OpenDKIM Filter v2.11.0 terminating with status 0, errno = 0
Jun 25 01:07:06 serv01 opendkim[30251]: OpenDKIM Filter v2.11.0 starting (args: -x /etc/opendkim.conf -P /var/run/opendkim/opendkim.pid)
Jun 25 01:07:07 serv01 postfix/smtpd[30019]: connect from unknown[185.143.75.81]
Jun 25 01:07:09 serv01 postfix/smtpd[29999]: connect from unknown[212.70.149.18]
Jun 25 01:07:13 serv01 postfix/postfix-script[30264]: stopping the Postfix mail system
Jun 25 01:07:13 serv01 postfix/smtpd[29932]: connect from unknown[185.143.72.16]
Jun 25 01:07:13 serv01 postfix/master[1514]: terminating on signal 15
Jun 25 01:07:13 serv01 dovecot: auth: Warning: auth client 0 disconnected with 1 pending requests: EOF
Jun 25 01:07:14 serv01 postfix/postfix-script[30349]: starting the Postfix mail system
Jun 25 01:07:14 serv01 postfix/master[30351]: daemon started -- version 3.4.7, configuration /etc/postfix
Jun 25 01:07:15 serv01 postfix/smtpd[30354]: connect from unknown[212.70.149.2]
Jun 25 01:07:21 serv01 postfix/smtpd[30359]: connect from unknown[185.143.75.153]
Jun 25 01:07:21 serv01 postfix/smtpd[30361]: connect from unknown[185.143.72.25]
Jun 25 01:07:22 serv01 postfix/smtpd[30354]: warning: unknown[212.70.149.2]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:07:22 serv01 postfix/smtpd[30363]: connect from unknown[212.70.149.18]
Jun 25 01:07:23 serv01 postfix/smtpd[30354]: disconnect from unknown[212.70.149.2] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:07:28 serv01 postfix/smtpd[30359]: warning: unknown[185.143.75.153]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:07:28 serv01 postfix/smtpd[30361]: warning: unknown[185.143.72.25]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:07:28 serv01 postfix/smtpd[30359]: disconnect from unknown[185.143.75.153] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:07:29 serv01 postfix/smtpd[30361]: disconnect from unknown[185.143.72.25] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:07:29 serv01 postfix/smtpd[30363]: warning: unknown[212.70.149.18]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Jun 25 01:07:30 serv01 postfix/smtpd[30363]: disconnect from unknown[212.70.149.18] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Jun 25 01:07:31 serv01 postfix/smtpd[30354]: connect from unknown[212.70.149.2]
Jun 25 01:07:38 serv01 postfix/smtpd[30363]: connect from unknown[185.143.72.34]
use https://www.ip2location.com/free/visitor-blocker and block by Fail2Ban
Sorry has been installed and configured for weeks, just doesn't seem to work !!!
I'm from the hosting business and I know how to administer a server!
KrzysztofMaciejewski Nice that you want to help, but to make everyone look as if they were the first day in busines
Domain has been changed!
server
listen 80;
listen 443 ssl http2;
server_name solutions.de aapan.solutions.de *.solutions.de;
root /www/wwwroot/solutions.de;
if ($allowed_country = yes) { return 403; }
#error_page 404/404.html;
limit_conn perserver 400;
limit_conn perip 15;
limit_rate 1024k;
#HTTP_TO_HTTPS_START
if ($server_port !~ 443){
rewrite /.*$ https://$host$1 permanent;
#HTTP_TO_HTTPS_END
ssl_certificate /www/server/panel/vhost/cert/solutions.de/fullchain.pem;
ssl_certificate_key /www/server/panel/vhost/cert/solutions.de/privkey.pem;
ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
#SSL-END
#Directory protection rules, do not manually delete
include /www/server/panel/vhost/nginx/dir_auth/solutions.de/*.conf;
#error_page 404 /404.html;
#error_page 502 /502.html;
#ERROR-PAGE-END
##SECURITY-START Hotlink protection configuration
location ~ .*\.(jpg|jpeg|gif|png|js|css)$
expires 30d;
access_log off;
valid_referers none blocked aapan.solutions.de solutions.de *.solutions.de;
if ($invalid_referer){
return 404;
#SECURITY-END
include enable-php-73.conf;
#PHP-INFO-END
include /www/server/panel/vhost/rewrite/solutions.de.conf;
#REWRITE-END
location ~ ^/(\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
expires 30d;
error_log on;
access_log on;
location ~ .*\.(js|css)?$
expires 12h;
error_log on;
access_log on;
access_log /www/wwwlogs/solutions.de.log;
error_log /www/wwwlogs/solutions.de.error.log;
CQT Hey man, I am assuming that the reason you are getting all of these attacks from China is because that's where the CP is from, and it looks to be very popular there. They probably scan the internet for certain footprints of the server and just try to get in any way they can. It doesn't look/sound like it's an issue of security of the software, just that it's targeted. Are you not using Cloudflare?
This is exactly my concern that CP comes from China and is misused to attack servers. Not all of our customers use Cloudflare. It is still possible to stretch the IPs of the servers on which the CP is installed and that is exactly what I consider to be very dangerous.
iam runing aapanel on 3 servers i never had any attacks from china but still jose is going to give solution on this..
