Hello friends, I have installed php version 8.1 in my aapanel, but the installed composer shows the following error when I run it. help me please.
-----------------------error------------------------------------------------------------------
composer self-update
PHP Deprecated: Return type of Symfony\Component\Console\Helper\HelperSet::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/bin/composer/vendor/symfony/console/Helper/HelperSet.php on line 112
    emzedam
    Hello, a compatibility problem is displayed. You are advised to follow the tips to resolve the problem
