Lionitch
Hello, this is a one line command, not two lines, use the following
cat /www/server/panel/vhost/letsencrypt/xxxxxxxxxxx/privkey.pem > /etc/ssl/private/pure-ftpd.pem
cat /www/server/panel/vhost/letsencrypt/xxxxxxxxxxx/cert.csr >> /etc/ssl/private/pure-ftpd.pem
Could not renew expired SSL (Let's Encrypt)
Hi, okay i run all the command and its successful. Then I rebooted the system and reopen FileZilla, but the certificate is still expired.
I try to renew it again manually on /site and it show "Local Authentication failed"
I found that the value of Private Key doesn't change. And there's 3 value of certificate.
[-----BEGIN CERTIFICATE----- (x3 times)]
is it normal?
My SSL still can't be renewed. Please help :
Lionitch
Close the SSL application and reapply. The SSL of this site has expired. You need to add relevant txt records to the domain name provider's website
Do the previous ftp certificate after successfully applying for SSL
Hi just a quick question,
1) By "reapply", does it mean to disable SSL then enable back?
2) where can i get relevant TXT records from Let's Encrypt?
so sorry im really new to all of this
- Edited
You can SSL from zerossl or amazon ssl get free 1 year ssl
- Best Answerset by Lionitch
Lionitch
After SSL is closed, you will be prompted to add txt records when you use DNS to verify the application. Do not close this window at this time. Copy relevant content to the domain name provider for txt record (or modification), wait about 10 minutes after it takes effect, and then go to the SSL window that is not closed for verification
If you use file validation, you do not need to add txt records.
If you uses CDN or redirect, you may not be able to apply and renew through file verification.
@"aaPanel_Kern" @"aaP_4hidessh"
Hi Kern and 4hidessh,
Thank you for your help. My SSL have been renew now
- Edited
i cannot renew my let's encrypt ssl. CA server was unable to access my website!
this the notification error:
*The connection timed out and the CA server was unable to access your website!**
Verify domain name:aduan.csirt.malangkota.go.id
Verify URL:Click to view
Verify content:mkRrR25c_HQUMsGftwBU9uTHz_x0oA3CbOfAQRMASEY
Error code:103.135.14.84: Fetching http://aduan.csirt.malangkota.go.id/.well-known/acme-challenge/mkRrR25c_HQUMsGftwBU9uTHz_x0oA3CbOfAQRMASEY: Timeout during connect (likely firewall problem)
Verify results: Verify failed
Please anyone give me the solution. thanks
Hello, it is recommended that you use DNS verification. The CA server cannot access your website.
Do not close the verification interface when manually adding relevant records when applying. Wait for the records to take effect before clicking Verify.
aaPanel_Kern thanks for recomendation. It's not a firewall problem?
Hello, it is generally possible. You need to modify the configuration file of the website, such as the information to connect to the database.
