• Support
  • Connecting to the isn't terminal not working.
thesnipe12
Post link:
No post link will not be able to know which user's information is
a month later
7 months later
got the same error, disabled "https" and now it is working fine
23 days later
Goodnight!
I'm having the same problem with authentication in the terminal. I can access it normally via putty, but via the aapanel terminal it succeeds and then disconnects with the message Connection lost, trying to connect again!
my vps is account linux version Ubuntu 20.04.6 LTS x86_64(Py3.7.9) aapanel is 6.8.28
    aaP_nicacio_tecnologia
    Hello, whether to use CDN, reverse proxy. Visit aapanel?
    If not, try to use the SSH tool to log in to the server and execute commands with root authority, and then try again. Is it possible to solve the problem?
    btpip install simple-websocket==0.10.0 -I && bt 1
      3 months later
      i got the same issue like this. i've tried upgrade to 6.9.75 version, click "fix" in aapanel homepage but it is still not working. Please give me some help.
      System that im using: CentOS 7.9.2009 x86_64(Py3.7.9)
        aaP_bobinmind999
        aaPanel_Kern Hello, whether to use CDN, reverse proxy. Visit aapanel?
          4 months later
          Very Nice. I fixed this problem by upgrading the panel from 6.8.31 to 6.8.33 by clicking the "Fix" button in the aapanel homepage.
          The system I am using is: Ubuntu 22.04 LTS
          7 months later
          Hello, is it possible to connect using other ssh tools? Are the username and password correct?
          bycomsol
