• Support
  • Panel not loading properly pop-up setting of apps and website setting?
kamranhanif496
I didn't have this problem when you opened it in your panel. What browser did you use to open it?
Or you try to open the panel in incognito mode
    aaPanel_Jose Chrome, no normal.
    But when I disable some extension it works for some time but after it again same problem.
    Thanks but this is not my main problem.
