im not installing mysql but still 100% load
100% CPU
aaPanel_Jose i've got same issue here.
can you help me please. i'll send you my panel login information.
thank you
- Edited
I'm also having the same issue when I try to stress test the server.
The issue is with php. I suspect aaPanel has poor handling of php processes.
I have posted several times in the forum and @aaPanel_Jose won't give a response
deewinc of course he will not answer. you don't give all the details, and you have a bad track record.
your tests https://www.aapanel.com/forum/d/4221-best-settings-for-nginx-on-wordpress-server-fails-loader-io-tests
are a joke. I don't mean to offend you but you still don't understand that "aapanel it's just an interface manager and nothing more."
deewinc Hello, you can open the php management ---- extension installation, install the opcache to try, this has a role in accelerating the parsing of php scripts, maybe you said other
aapanel_power for the record: I'm very happy with aapanel. I use Nginx+php7.4+MariaDB+mailserver
It's enough for me. I like keeping things simple and I don't expect everything on a platter. As for OS, I'm using Centos 7 for over a year, and I test ubuntu 20 now. The only minor issues I can think of now are the MariaDB (10.4.ZZ) update and the Apcu 5.1.20 update.
aapanel_power ~ I will pull you over to the post where I did the stress tests.
The forums keeps on going offline. Could have posted earlier.
Stealth well I am using 1 core cpu and 1gb ram and yea wordpress site Cyberpanel handles it well
aaPanel_Jose
I have a similar problem: PHP-FPM get a lot of CPU, often 100%, and Mysql crash.
What do you mean with opcache plugin for php ?
aaP_webmatser opcache cache for speeding up PHP scripts! is installed
вся проблема походу вот в чём
There were 16418 failed login attempts since the last successful login.
Darklordx265 well I am using 1 core cpu and 1gb ram and yea wordpress site Cyberpanel handles it well
CyberPanel runs on OpenLiteSpeed or LiteSpeed and it gives the same performance with aaPanel and OLS with Litespeed Cache Plugin.
aaP_webmatser I have a similar problem: PHP-FPM get a lot of CPU, often 100%, and Mysql crash.
Are you running on Nginx? You need to enable FastCGI
