If there is no solution and it's not going to function anymore, please just let me know so that I switch to another control panel.
Thanks
Thanks
dont forget to mention the code after port
if you forget the code find on history browser
thanks
i use version 7.0.10. Menu Docker, tab compose not woking and tab tempalte not display
Hello, thanks for your feedback, we will fix it
need help plz
Hello, this problem has been fixed. Click "Fix" on the homepage to fix it, wait for a while and try again.
aaPanel_Kern ty now work
I'm still using Centos 7, please provide a solution, thanks
Hello, can you use the ssh tool to log in to your server and then execute the following command to fix it?
rm -f /tmp/update_to7.pl && curl -k https://node.aapanel.com/install/update_7.x_en.sh | bash
I have already used Repair Method 3 override the installation with the install command
curl -sSO http://www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh
thank you for the solution, I will try it if it recurs with the same problem :
nuhajat will it ruin the existing websites and configurations?
Hello, what problem did you encounter? Is there any log information? Overwriting the installation will not lose data, and the aapanel username and password will be changed.
hello, if I click and run "Fix" buttons, will it delete websites, settings, databases, cron jobs, etc.?
Hello, no, the repair only updates the repair panel and does not affect the website, etc.
It is recommended that you make a backup of the server before operation
