check ur recyclebin
How to fix disk full 100%
Hello...
I have a problem with File Manager, I have several websites online
I don't know when, a file like this always appears which causes my Disk to fill up. and strangely, every second the size of the file continues to increase
what I have done:
- delete the file, after deleting it a file like that appears again with a different file name, but the problem remains the same
- turn off all running crons
- restart BT
- update aaPanel to v7.0.8
help pls @aaPanel_Jose @aaPanel_Kern
Brain
Hello, I suggest you check what's inside? Use the command: tail -n 50 files
if i open the file
its crazy
- Edited
if i do
#tail -n 50 zivxunr9
and now there are two unknown files, and the size of the files is increasing every second, and it reaches 100GB in less than 30 minutes
- Edited
same to me, now i cant open my aapenl since i update to 7.0.8 also.
https://www.aapanel.com/forum/d/21576-unable-to-open-my-panel-after-disc-full
my aaPanel so bad after i update to v7.0.7 until now v7.0.8
How many total disks do you have in aaPanel?
and, are you using your own server?
mybe you can tryna restart your aaPanel VM
100 and added 50gb again. now can open back. but db cant work normally
- Edited
can you access aaPanel with ssh?
mybe you can try to Repair Panel
Brain I finally back to normal after upgrade mysql and the panel.
Brain Yeah i ady do it and maybe window firewall is block. Now is normal.
aaP_felix1230123
cool
and my problem is, I don't know where this file came from, and its size keeps increasing every second
Hello, you can use this command multiple times to check which program is using this file.
lsof 文件名
