Moultrex aaPanel_Jose Sorry i was meant to say ON-DEMAND mode. Sorry on-demand is missing currently. pm = ondemand
aaPanel_Jose wa44io4 Knowing that the problem has been fixed, you can try the repair panel to solve it
c1ne There is a bug on this forum. It does not automatically redirect to https. I clicked a link to this forum on the footer of my aapanel and it does not use https so the non-https of this forum are broken.
aaPanel_Jose JAY Sorry to develop a plugin is not something I can decide for myself, I will inform you if there is progress
Onichan [root@srv8996 ]# curl -sSO www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh curl: (7) Failed connect to www.aapanel.com:80; No route to host [root@srv8996 ]# curl -sSO www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh curl: (7) Failed connect to www.aapanel.com:80; No route to host [root@srv8996 ]# curl -sSO www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh curl: (7) Failed connect to www.aapanel.com:80; No route to host [root@srv8996 ]# curl -sSO www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh curl: (7) Failed connect to www.aapanel.com:80; No route to host [root@srv8996 ]# how can i resolve it?
TheWormsUnited Onichan whats your machine production? have a look at this link: https://www.aapanel.com/reference.html
jazz1611 @aaPanel_Jose hello, how to limit log size access and error in nginx/apache? now it more 20GB access log at per domain 😐
TheWormsUnited jazz1611 have a look at this to fix your problems: http://httpd.apache.org/docs/2.0/programs/rotatelogs.html also this: https://stackoverflow.com/questions/11438330/how-can-i-limit-the-size-of-apaches-access-log-and-limit-the-number-of-archive
aaPanel_Jose Onichan This is the correct installation command, the command you executed is missing the protocol http curl -sSO http://www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh
jazz1611 need have button fix permission 644 for file and 755 for folder in file manager, please. after uncompress, all file and folder will set 755.
v1sh4l Hello please make the panel mobile responsive. See other panels like cyberpanel. They are good in accessing in mobile device
