adampsb I have a problem with my server, my database server cannot be accessed. even though the username and password that I entered are correct. here the error what i get : this i access from terminal : this i try to access :
aaPanel_Jose adampsb Is your mysql server started? Try restarting the mysql server in the command to see if anything happened? restart command /etc/init.d/mysqld restart
amrgamal aaPanel_Jose I have the same problem and I put the steps you mentioned here and the solution is not working please help
aaPanel_Kern amrgamal Restart mysql command: /etc/init.d/mysqld restart If there is an error after restarting, please check the mysql log: cat /www/server/data/*.err|grep -i -C 10 error
