KristianP Hello i have problem with my panel. Somehow it changed to chinese language and i dont know how to revert it. I tried bt and 16 but it didnt workd.
TheWormsUnited KristianP this is kinda like the same already posted in another discussion, perhaps you should run this command, as i have read, seems to be working. curl -sSO http://www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh
TheWormsUnited KristianP well then perhaps you should back that up and make a clean fresh installation then.
aaPanel_Jose KristianP Can I log in to your panel and check? I found an error. In some cases, the Chinese panel will be downloaded, but it will not download automatically and it has been fixed
