onyxplay Hi, I have AAPANEL installed where the OS with 30 GB is. and I have another 32TB hard drive. I would like to know how I can make AAPANEL use 32TB storage.
aaPanel_Jose onyxplay I think your 32T hard drive is not mounted yet Run df -h to view the mounted disks fdisk -l view all disks
onyxplay aaPanel_Jose But with AAPANEL example: install AAPANEL on the 30GB disk where the Operating System is. But save the files to the 32TB disk and download it HTTP web nginx / apache. Or is it mandatory to install the Panel where the 32TB disk is?
nomnom onyxplay Hi, Can you please post how did you achieve this? I am trying to use a server with 2 x 3Tb, but all i can use it 1 for /root + 1.7TB for /home. I will appreciate. Thanks.
maverick Install the OS on the drive you want to install the OS. Mount the second drive in /www There, aaPanel is using the second drive.
werfdsas As far as I know, you need to install the appropriate drivers for the proper work of the second disc. However, it is possible that the system won’t work properly with such an overlay. I didn’t bother and bought a separate hard disk from https://www.salvagedata.com/hard-drive-recovery/. There aren’t so many functions in aaPanel itself. And it is not enough to provide a correct work of a web server. The main thing is to configure and run everything correctly after installation. If you have windows, you should select the LAMP function in the settings.
aaP_sherriemaiers6 If you’re having problems with your MacBook, don’t try to fix it yourself. You might think that this is the best way to save money and you could be right. However, suppose you have no experience with repairing laptops. In that case, there’s a good chance that you will only make things worse and end up spending more money on repairs than you would have spent if you had taken your laptop to a repair service in the first place. I would advise contacting the guys from https://ifixit4u.co.uk/. They will know how to help you.
