aaP_ozochidi1 hello please i have some issues here, after a installation, but my appanel url is not loading , what do you suggest
aaP_tenoilrug wget -O install.sh http://www.aapanel.com/script/install-ubuntu_6.0_en.sh && bash install.sh forum not working
aaPanel_Kern aaP_tenoilrug Hi, it has now been restored. Please execute the installation command again. thanks
aaP_audreynogueira07 I can't access my panel again. I only could once when I did the installation. But now I can't ... I put my IPV4 + port and the screen just keep white without something to show.
aaPanel_Kern aaP_audreynogueira07 Hello, please enter the security entry, if you forget, please use the command to view: bt 14
aaP_pcdrips Am facing this error while updating my php configuration details.This happen after i have done latest upgrade of aapanel.I think your latest upgrade have bug which lead to this error
aaPanel_Kern aaP_pcdrips Hello, this is a bug and we will fix it. You can modify the configuration file directly. Make sure to backup first
aaPanel_Kern Christina Hello, please wait for our repair, you can directly modify the configuration file first, as shown in the figure Copy "post_max_size" and then go to "Configuration file" and press Ctrl+F to search
aaP_abubakarabdurrahman303 hi @aaPanel_Jose aaPanel_Kern @Aapanel please i need help. I installed aapanel in my ec2 in AWS but when i install the aapanel after i get the link to go to the panel I`m not able to go there(the admin panel) i try all the alternate ports but it still didn't work this is the ip address and port that i get after the successful installation http://xxxxxxxxxxx:7800/ which is my servers public address please help me
aaPanel_Kern aaP_abubakarabdurrahman303 Hello, please check whether the aapanel port is open in the AWS security group.
aaP_abubakarabdurrahman303 aaPanel_Kern please sorry but i didn`t understand did you mean that i should go to my network config and allow some ports like in inboud rules at firewall?. if its that i allow anything even ssh i allow it as any type ip address
