Hi, here's my situation:
I've got 9 websites in my aaPanel installation that's running version 6.8.26 on an Ubuntu 20.04.5 server.
And i use Nginx with php 7.4 on all sites.
Then all my sites use cloudflares ssl and https are active on all of them.
Here's the config from the non working domain, seems to be the same for all my websites, I have replaced the domain with FAKEDOMAIN.COM
`server
listen 80;
listen 443 ssl http2;
server_name FAKEDOMAIN.COM;
root /www/wwwroot/FAKEDOMAIN.COM;
#error_page 404/404.html;
#HTTP_TO_HTTPS_START
if ($server_port !~ 443){
rewrite ^(/.*)$ https://$host$1 permanent;
#HTTP_TO_HTTPS_END
ssl_certificate /www/server/panel/vhost/cert/FAKEDOMAIN.COM/fullchain.pem;
ssl_certificate_key /www/server/panel/vhost/cert/FAKEDOMAIN.COM/privkey.pem;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
#SSL-END
#error_page 404 /404.html;
#error_page 502 /502.html;
#ERROR-PAGE-END
include enable-php-74-wpfastcgi.conf;
#PHP-INFO-END
include /www/server/panel/vhost/rewrite/FAKEDOMAIN.COM.conf;
#REWRITE-END
location ~ ^/(\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
expires 30d;
error_log /dev/null;
access_log off;
location ~ .*\.(js|css)?$
expires 12h;
access_log off;
access_log /www/wwwlogs/FAKEDOMAIN.COM.log;
error_log /www/wwwlogs/FAKEDOMAIN.COM.error.log;
