aaPanel_Jose
server is linux debian 9
mysql is installed 8.0.19
apache wont install either but i didnt think i needed it
phpmyadmin not install in aapanel
norge how did you made this aapanel installation without the apache?
TheWormsUnited apache wont install like phpmyadmin i need php 7.3 version
- Edited
Have you updated the latest version 6.6.0 of aaPanel?
TheWormsUnited i updated today
did they fix issue in this update?
TheWormsUnited after update tried to instal php 7.4 still cant
im uninstall nginx and install apache see if i can install php 7.4 phpmyadmin
norge I would recommend a fresh installation of aaPanel 6.6.0
TheWormsUnited i think i know why well upon reinstall of mysql this service is stopped like it was before, is there a way to start it since pressing restart start isnt working
norge try this:
service mysqld stop
then:
service mysqld reload
more info here:
https://www.aapanel.com/reference.html
TheWormsUnited no the start stop restart wasnt working i changed the version of mysql and said running
norge So working now?
TheWormsUnited no php 7.3 doesnt install
i can only install lowest version of php, at that point i still need a higher version of php
norge yes i understand that, perhaps @aaPanel_Jose can help you with that, maybe a bug!
