jazz1611 hello, after update version from 6.3.3 to latest. i get error when access to panel in SSH, have error with command "bt" too root@Ubuntu-1804-bionic-64-minimal ~ # bt -bash: /usr/bin/bt: /bin/bash: bad interpreter: Text file busy
aaPanel_Jose Hello jazz1611 Try to change the /usr/bin/bt file first line #!/bin/sh to #! /bin/sh and try bt command again If work change/etc/init.d/bt too
people Seems lets encrypt has broken...! Stuck on Applying for a certificate... No further results...
aaPanel_Jose Hello people May I ask which ssl application method you are using, where is it stuck? Can you give me a screenshot
people again the problem persists after a reinstall btw i already did Hello jazz1611 #!/bin/sh to #! /bin/sh /etc/init.d/bt too
aaPanel_Jose people I tested it on aws server and it worked well. Can I log in to your server and check it?
