my website is not getting updated whenever I add anything new it shows only the previous content I tried to delete caches from the plugin I even tried deleting the plugin itself but nothing is working for me please help me solve this problem.
    what is that
    I don't know what that is?????
    but if I try to put /?v=123 after my post URL everything works fine I then see the updated content
    I don't know what is going on
    3 years later
    Hi Thanks for the reply I use the cache plugin that from aapanel in wordpress I do not have cdn.
    I tried to delete the cache from wordpress, from aapannel and also from the BT panel in ssh but nothing, I also tried to change php and mysql but the problem always persists as a server I use ubuntu server 24.04.2 LTS I did other installations but nothing with previous versions of aapanel never had problems, very strange in wordpress logged in the changes to the pages are displayed but when you log out everything remains unchanged no changes are displayed
      yes even changing browser edge, crom, brave. pinging the server responds but then tell me where I can find a previous version of aapnel to try
        Hello, the aaPanel version will not affect the website. Is it recommended that you clear it successfully in the background of the website?
        aaP_alessandropetrone
        I've done it several times, I've reinstalled Ubuntu Server and installed Aapanel, I use Proxomox for VPNs but this has never happened to me, now I'll install it in AWS and I'll tell you
        I installed everything on aws the problem is the same see for yourself
        WORDPRESS
        Hello,
        It is recommended that you check what configuration you have made, and the access link shows a 404 error.
        and this is exactly the problem I changed the theme and I put a default one it simply reads the old woodmart theme enter in107.20.211.44:13710/3a4afc77 and check also see conf ddi wordpress changing theme
          Hello, I haven't seen you have Woocommerce and 2024 upload file directory
          It is recommended that you check whether the website's files are complete first
          I reinstalled everything, deleted the old wordpress and installed it again but aapanell always reads the old one and like the aapanell cache I didn't delete any files
          how is it possible that it reads the wordpress installation that I had before I deleted and reinstalled a new installation but aapanell reads me an installation that is no longer there this is the problem that I encounter and not only on AWS servers but also on servers installed on Proxomox and google cloud
          Hello, you can modify the RT_WP_NGINX_HELPER_CACHE_PATH in wp-config.php to:
          define( 'RT_WP_NGINX_HELPER_CACHE_PATH', '/www/server/fastcgi_cache' );
          Thanks @aaPanel_Kernyes this was the problem now everything works I hope that our posts can be useful to other users too
