my website is not getting updated whenever I add anything new it shows only the previous content I tried to delete caches from the plugin I even tried deleting the plugin itself but nothing is working for me please help me solve this problem.
cache problem
- Best Answerset by aaP_umarzaib136
aaP_umarzaib136
Are you using a CDN?
- Edited
what is that
I don't know what that is?????
but if I try to put /?v=123 after my post URL everything works fine I then see the updated content
I don't know what is going on
no no no I am not using any content delivery network
aaP_umarzaib136
Are the resources you are accessing static files? For example js css html etc
I have installed WordPress on my server
please Jose sir help me
aaP_umarzaib136 vocĂȘ esta usando algum plugin de cache no Wordpress?
aaP_umarzaib136 are you using any WordPress caching plugin?
I have the same problem
Hello, I suggest you describe the problem in detail. Are you using cache plugins and CDN?
- Edited
Hi Thanks for the reply I use the cache plugin that from aapanel in wordpress I do not have cdn.
I tried to delete the cache from wordpress, from aapannel and also from the BT panel in ssh but nothing, I also tried to change php and mysql but the problem always persists as a server I use ubuntu server 24.04.2 LTS I did other installations but nothing with previous versions of aapanel never had problems, very strange in wordpress logged in the changes to the pages are displayed but when you log out everything remains unchanged no changes are displayed
Is it normal to change the browser or use traceless mode to access it?
Is it normal to clear cache using WordPress backend?
yes even changing browser edge, crom, brave. pinging the server responds but then tell me where I can find a previous version of aapnel to try
Hello, the aaPanel version will not affect the website. Is it recommended that you clear it successfully in the background of the website?
I've done it several times, I've reinstalled Ubuntu Server and installed Aapanel, I use Proxomox for VPNs but this has never happened to me, now I'll install it in AWS and I'll tell you
- Edited
I installed everything on aws the problem is the same see for yourself
WORDPRESS
Hello,
It is recommended that you check what configuration you have made, and the access link shows a 404 error.
and this is exactly the problem I changed the theme and I put a default one it simply reads the old woodmart theme enter in https://107.20.211.44:13710/3a4afc77 and check also see conf ddi wordpress changing theme
I gave you the login credentials but did you delete them?
