aaPanel_Kern aaP_kotakomputer.ceo Hello, it has been tested that it is not supported to change the ip of the system established in the lxc container.
aaP_kotakomputer.ceo aaPanel_Kern thanks for you info. Hope in the next version aaPanel support Add IP on LXC (like CPanel does).
aaPanel_Kern filmovtv Hello, as long as it is not a container, you can add ip, have you encountered any problems?
filmovtv I have not yet ordered an additional IP from a provider, before ordering I decided to ask if there would be any problems with adding an IP to aaPanel, OS Debian 11.
aaPanel_Kern filmovtv Hello, the plugin does not support Debian 11 yet, But you can add ip manually which is very simple. The provider will also have a tutorial on how to operate. You can also ask the provider to set the ip for you
aaP_kotakomputer.ceo aaPanel_Kern Any update please? When aaPanel support Proxmox Container (LXC) using muti IP?
aaPanel_Kern Hello, it is not supported. If you add an IP, it is recommended that you make a backup and then add it manually, or ask the server provider to handle it for you. AhmedMohebIT
AhmedMohebIT aaPanel_Kern Thanks I added it manually and it works and I tested it while adding a new Subdomain. I have another problem how do I use both IP addresses with the Mail Server?
