iqbalfaf Hi, I am a new user, I want to ask how to create a website for localhost I try to add a site with a domain 127.0.0.1 can not.
iqbalfaf https://prnt.sc/pv9aau I want to change this look to the web that I want, I look for the default directory, I can't find it. Please help
dat Hi this solution work for 1 localhost site and wat if we need to have many oder localhost site or apps ... ???!!!
aaP_kotakomputer.ceo Edit C:\Windows\System32\drivers\etc\hosts Put your domain name in this hosts file as: 192.168.1.199 mysite-001 192.168.1.199 mysite-002 192.168.1.199 mysite-003 Then on aaPanel add 3 sites: mysite-001, mysite-002, mysite-003 NB: you need to run Notepad as Administrator to edit hosts file. To save hosts file you may enter as filename: "hosts"
aaP_mendozasj See if it works for you. Minute 09:53 https://youtu.be/UMf_KfzsaJ4?si=FtB4FgI_RE5EhvIv&t=594
