Hello,
I have a problem with DNS, I can't add Default NS because if I type the address alone e.g. ns1.blabla.com and n2.blabla.com I get a message that the addresses should be accepted at the same time.
What I have found is that entering ns1.blabla.com, Public IP / NS IP results in a positive save, but when I enter the Default NS option again, the data I entered there disappears.
For Default NS, does a new domain have to be created?
I have my domain develo**.pl, the IP address and server names "ns1.de******.pl" disappear when I check to see if they have actually been saved.
I also have a problem with other things, namely generating the SSL form and setting the DNS servers. I'm already lost in this...
Maybe I should just wait until the DNS's are saved and updated because I seem to have everything done correctly, but I keep encountering the inability to connect to the site etc.
I also have 2 domains, on 1 domain provider portal. blabla1 and blabla2. Both domains are configured the same.
I will add that I have the entire server at my home.
On the router were unblocked ports 80 and 443, redirected to the IP address of the server on which was installed aapanel.
On the server I have DNS Manager, I added there the appropriate domain and generated me ns and IP.
At domain provider I added these server ns and my public IP.
The site blabla1, can be launched from time to time. Other people can connect to it etc. The blabla2 domain, having the same settings from the beginning is not able to connect.
I'm a complete novice, I decided to create a hosting for my websites and I'm just learning all about Linux etc.
I've already spent 3 days and 2 nights on this and I don't think I can solve it by myself. I've read almost the entire forum and half of google, but I still haven't managed to solve the problem, which is probably child's play.
Could someone from aaPanel verify the correctness of my actions and explain to me how I can add a default NS so that all my domains which I will buy from the provider can be routed using 1 permanent ns server?
I will send the appropriate person any necessary data / recordings of what is happening.
Greetings and regards,
Marcin
