New server.
1: I choosed to install LAMP.
The installation completed.
2: MySQL weren't installed. It says completed, but the MySQL package isn't there. I choosed mariadb 10.4
3: I then tried installing the MySQL package again. It says completed. No MySQL package. (I am trying to migrate with the one click tool, but it says please install MySQL first.
4: I then tried to press fix panel. Completed.
Issue not solved.
5: I then tried to press update panel. Does not complete with error quoted below.
It is about a timed out connection to brandnew.aapanel.com, so I tried to SSH into the server and wget brandnew.aapanel.com, it also fails. Wget everywhere else works, both 80 and 443.
Errors and details below:
REQUEST_DATE: 2021-12-07 15:01:07
PAN_VERSION: 6.8.17
OS_VERSION: CentOS Stream 8 x86_64(Py3.7.8)
REMOTE_ADDR: 46.9.148.96
REQUEST_URI: POST /plugin?action=get_soft_list
REQUEST_FORM: {'p': '1', 'type': '-1', 'tojs': 'soft.get_list', 'force': '0', 'query': ''}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36
`Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 157, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_socket3.py", line 335, in connect
raise error(err, strerror(err))
TimeoutError: [Errno 110] Connection timed out
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 300, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno 110] Connection timed out
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 110] Connection timed out'))
File "/www/server/panel/BTPanel/init.py", line 1578, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1526, in run
File "class/panelPlugin.py", line 677, in get_soft_list
softList = self.get_cloud_list(get)
File "class/panelPlugin.py", line 353, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 116, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 60, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 110] Connection timed out'))`
[root@webserver ~]# wget brandnew.aapanel.com
--2021-12-07 15:06:08-- http://brandnew.aapanel.com/
Resolving brandnew.aapanel.com (brandnew.aapanel.com)... 107.151.154.153
Connecting to brandnew.aapanel.com (brandnew.aapanel.com)|107.151.154.153|:80... ^C
[root@webserver ~]# wget brandnew.aapanel.com:443
--2021-12-07 15:06:19-- http://brandnew.aapanel.com:443/
Connecting to brandnew.aapanel.com (brandnew.aapanel.com)|107.151.154.153|:443... ^C
