deewinc
openlitespeed has been updated to 1.7.14
aaPanel 6.9.57 (beta) released on 26 Nov. 2021
How can I install PHP8.1? It was released for a while
DazaiYuki
Currently php8.1 plug-in library is still being sorted out, we will launch it next week
@aaPanel_Jose any plan support ipv6 only vps?
aaP_strong
Thank you for your feedback, we are working on it
When I join the beta. Am I able to leave it again?
ta_ihpoj1jophi_at Yes, you will have an option to return stable version.
lailton , thank you so much. I was totally afraid to press the button.
Hi Jose, thank You for the update, great work Sir! I already try the 6.9.57(beta). But I'm sorry, just wanna let You know that the problems with ssl thing still persist. 1. Cant open the panel with ssl with our own key and 2. Lets encrypt still not work. Thank You!
Hello guyss, i want to know something
Does aapanel needs vps for website hosting like wordpress?
can it will be connect with aws or oracle cloud?
How to access aapanel like cpanel from anywhere any internet??
thanks in advance
@aaPanel_Jose
hello, please add feature backup all database in 1 click
jazz1611
The backup clicked on the database page is instant, it will block the operation of the panel, you can add the task of backing up all databases in Cron and click Execute
any plans to enhance support for arm processors and oracle Linux 8?
yahia
Oracle's arm cloud server, you can try debian10
aaPanel_Jose It doesn't have Debian, only Ubuntu.
there is no support for mail server in arm architecture maybe next update
it shows this when try to install mail server Does not support non-x86 system installation
