zonex Anybody can tell me how to configure the panel or the CloudFlare settings to make work perfect with aaPanel? When I put proxy tunnel pass trought the webs passing by CloudFlare dns don’t work, actually I just have TS3Servers.es domain (this is also the main link of panel) add as website. thanks
aaPanel_Jose zonex CloudFlare can only proxy port 80 443, the panel is port 8888, I think you need to resolve a panel-specific domain name and set this domain name to dns only in CloudFlare.
zonex I wanna put proxy on websites and when I add on cloudflare settings it gets a loop redirect and don’t show webs/panel
JAY iam using panel on cloudflare i dont face any error please check again and change port of panel HTTPS ports supported by Cloudflare: 443 2053 2083 2087 2096 8443 https://support.cloudflare.com/hc/en-us/articles/200169156-Identifying-network-ports-compatible-with-Cloudflare-s-proxy
JAY i think its redirecting http to https in 2 locations one is CF and in your AApanel check disable one , check in CF rules for http to https redirect and off it https://blog.cloudflare.com/content/images/2017/07/image2-1.png
zonex I had the CF rule off, but I just turn it on and then turned off on aaPanel (force https) and then now works, thanks
aaP_kotakomputer.ceo To make aaPanel works with CF: aaPanel: Enable SSL and set Force HTTPS = Enable aaPanel: check your .htaccess must not include any force HTTPS code, otherwise you will see Error redirecting CF: Choose SSL Mode = Full CF: Cache =Purge Everyting Browser: Clear cache
click2swapnil I had same problem today, I am new to cloudflare. My site was working fine when I simply added it to the cloudflare but my panel url was not able to access at port 7800 , then after trial and errors , I found it is just simple problem. You need to disable the proxy for the A or CNAME record for the subdomain/domain on which you are using the aapanel after disabling proxy for it. Problem solved and I can access the aapanel now. I used this resources https://developers.cloudflare.com/fundamentals/reference/network-ports/ https://developers.cloudflare.com/dns/manage-dns-records/reference/proxied-dns-records/
aaP_bestperson Hello, change the port in the panel to 2080, first open it in the security tab. You can also add a domain and issue a certificate, it's that simple
frcan89 Hola hoy presente el mismo inconveniente solo con desavilitar el forzado https en aapanel fue suficiente, gracias por la informacion que han compartido fue de gran ayuda
