utf8_unicode_ci not work in mysql
even i reported this a year back no solution
Sir, please take a look at this topic
Hello shajal
Can you provide me with the login information of the panel? If you can, please send your login information to jose@aapanel.com and I will arrange a time to check it for you
JAY
Maybe I was too busy to follow up for you, sorry
sir, I just give you sir
shajal
Hello
I did not receive your next reply email, your backup data contains an abnormal code, please try to create a test website in cpanel and restore the data to see if it can be displayed normally
i can share a friend test site to test same issue
iam available on discord
https://discord.gg/NsnQY2nzVd
You know you can change that directly on the database or database server right?
A google search will help you, this was the first link, I'm sure you can find others.
Thanks but I have already completed my work
- Edited
shajal
Can you share your process to help other users who have encountered this problem?
It is not complete. There are many problems in text. I will share it with you after clearing it completely
- Best Answerset by aaPanel_Jose
use MySQL 5.6.50 . mysql_mariadb don't support bangla
we have same problem from Russian site migrated from plesk to aapanel how to fix
JAY
Check if the encoding of the database is the same? Check the website's error log for what it says
i dont have any problem importing database in other like cyberpanel and other free panels only problem with aapanel..
