maverick Since this last update I can't install Let's Encrypt certificates. It validates then I get stuck on the window saying "Saving..."
aaP_mihailovs2000 Не работают крон - бэкапы сайтов и баз данных! Если самому нажать "выполнить", то всё хорошо!
jazz1611 aaPanel_Jose tried repair panel bt 16 in SSH not work. run command install aapanel again not work too.
aaPanel_Jose jazz1611 Thanks for the feedback, we will reply you again after the repair update: This problem has been fixed, please fix the panel
aaPanel_Jose aaP_fed9mail I just tested this and found that the self-signed certificate is displayed normally. Can you give me your certificate generation method, can I test it? Or you generate one to me jose@aapanel.com
aaP_fed9mail aaPanel_Jose My certificate generation method: openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/ssl/private/nginx-selfsigned.key -out /etc/ssl/certs/nginx-selfsigned.crt also i sent the certificate by mail
aaP_funid can somebody help me with my SSH connection error? i tried to access my aapanel but there is an error that suggesst me to access it via SSH
