MySql is running. This is what i saw in the error log.
230802 3:48:52 [Note] Plugin 'FEDERATED' is disabled.
230802 3:48:52 InnoDB: The InnoDB memory heap is disabled
230802 3:48:52 InnoDB: Mutexes and rw_locks use GCC atomic builtins
230802 3:48:52 InnoDB: Compressed tables use zlib 1.2.11
230802 3:48:52 InnoDB: Using Linux native AIO
230802 3:48:52 InnoDB: Initializing buffer pool, size = 16.0M
230802 3:48:52 InnoDB: Completed initialization of buffer pool
InnoDB: The first specified data file /www/server/data/ibdata1 did not exist:
InnoDB: a new database to be created!
230802 3:48:52 InnoDB: Setting file /www/server/data/ibdata1 size to 10 MB
InnoDB: Database physically writes the file full: wait...
230802 3:48:52 InnoDB: Log file /www/server/data/ib_logfile0 did not exist: new to be created
InnoDB: Setting log file /www/server/data/ib_logfile0 size to 5 MB
230802 3:48:52 InnoDB: Log file /www/server/data/ib_logfile1 did not exist: new to be created
InnoDB: Setting log file /www/server/data/ib_logfile1 size to 5 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: 127 rollback segment(s) active.
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
230802 3:48:52 InnoDB: Waiting for the background threads to start
230802 3:48:53 InnoDB: 5.5.62 started; log sequence number 0
230802 3:48:53 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
230802 3:48:53 [Note] - '0.0.0.0' resolves to '0.0.0.0';
230802 3:48:53 [Note] Server socket created on IP: '0.0.0.0'.
230802 3:48:53 [Note] Event Scheduler: Loaded 0 events
230802 3:48:53 [Note] /www/server/mysql/bin/mysqld: ready for connections.
Version: '5.5.62-log' socket: '/tmp/mysql.sock' port: 3306 Source distribution
230802 6:31:36 [Note] /www/server/mysql/bin/mysqld: Normal shutdown
230802 6:31:36 [Note] Event Scheduler: Purging the queue. 0 events
230802 6:31:36 InnoDB: Starting shutdown...
230802 6:31:37 InnoDB: Shutdown completed; log sequence number 1595675
230802 6:31:37 [Note] /www/server/mysql/bin/mysqld: Shutdown complete
230802 6:31:38 [Note] Plugin 'FEDERATED' is disabled.
230802 6:31:38 InnoDB: The InnoDB memory heap is disabled
230802 6:31:38 InnoDB: Mutexes and rw_locks use GCC atomic builtins
230802 6:31:38 InnoDB: Compressed tables use zlib 1.2.11
230802 6:31:38 InnoDB: Using Linux native AIO
230802 6:31:38 InnoDB: Initializing buffer pool, size = 16.0M
230802 6:31:38 InnoDB: Completed initialization of buffer pool
230802 6:31:38 InnoDB: highest supported file format is Barracuda.
230802 6:31:38 InnoDB: Waiting for the background threads to start
230802 6:31:39 InnoDB: 5.5.62 started; log sequence number 1595675
230802 6:31:39 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
230802 6:31:39 [Note] - '0.0.0.0' resolves to '0.0.0.0';
230802 6:31:39 [Note] Server socket created on IP: '0.0.0.0'.
230802 6:31:39 [Note] /www/server/mysql/bin/mysqld: ready for connections.
230802 6:31:46 [Note] Plugin 'FEDERATED' is disabled.
230802 6:31:46 InnoDB: The InnoDB memory heap is disabled
230802 6:31:46 InnoDB: Mutexes and rw_locks use GCC atomic builtins
230802 6:31:46 InnoDB: Compressed tables use zlib 1.2.11
230802 6:31:46 InnoDB: Using Linux native AIO
230802 6:31:46 InnoDB: Initializing buffer pool, size = 16.0M
230802 6:31:46 InnoDB: Completed initialization of buffer pool
230802 6:31:46 InnoDB: highest supported file format is Barracuda.
230802 6:31:46 InnoDB: Waiting for the background threads to start
230802 6:31:47 InnoDB: 5.5.62 started; log sequence number 1595675
230802 6:31:47 [Note] Recovering after a crash using mysql-bin
230802 6:31:47 [Note] Starting crash recovery...
230802 6:31:47 [Note] Crash recovery finished.
230802 6:31:47 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
230802 6:31:47 [Note] - '0.0.0.0' resolves to '0.0.0.0';
230802 6:31:47 [Note] Server socket created on IP: '0.0.0.0'.
230802 6:31:47 [Note] Event Scheduler: Loaded 0 events
230802 6:31:47 [Note] /www/server/mysql/bin/mysqld: ready for connections.
230803 7:52:50 [Note] /www/server/mysql/bin/mysqld: Normal shutdown
230803 7:52:50 [Note] Event Scheduler: Purging the queue. 0 events
230803 7:52:50 InnoDB: Starting shutdown...
230803 7:52:50 InnoDB: Shutdown completed; log sequence number 1595675
230803 7:52:50 [Note] /www/server/mysql/bin/mysqld: Shutdown complete
230803 7:52:52 [Note] Plugin 'FEDERATED' is disabled.
230803 7:52:52 InnoDB: The InnoDB memory heap is disabled
230803 7:52:52 InnoDB: Mutexes and rw_locks use GCC atomic builtins
230803 7:52:52 InnoDB: Compressed tables use zlib 1.2.11
230803 7:52:52 InnoDB: Using Linux native AIO
230803 7:52:52 InnoDB: Initializing buffer pool, size = 16.0M
230803 7:52:52 InnoDB: Completed initialization of buffer pool
230803 7:52:52 InnoDB: highest supported file format is Barracuda.
230803 7:52:52 InnoDB: Waiting for the background threads to start
230803 7:52:53 InnoDB: 5.5.62 started; log sequence number 1595675
230803 7:52:53 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
230803 7:52:53 [Note] - '0.0.0.0' resolves to '0.0.0.0';
230803 7:52:53 [Note] Server socket created on IP: '0.0.0.0'.
230803 7:52:53 [Warning] 'user' entry 'root@mail.drreddys.biz' has both a password and an authentication plugin specified. The password will be ignored.
230803 7:52:53 [Note] Event Scheduler: Loaded 0 events
230803 7:52:53 [Note] /www/server/mysql/bin/mysqld: ready for connections.
230803 7:57:08 [Warning] 'user' entry 'root@mail.drreddys.biz' has both a password and an authentication plugin specified. The password will be ignored.
