• Support
  • (docker) admin panel connection refused
I install aapanel in a VM ()virtual machine) and a VPS from aapanel/aapanel (docker hub).
bt 14 says:
EXECUTING
aaPanel default info!
aaPanel Internet Address: http://187.22.xxx.xxx:8110/
aaPanel Internal Address: http://172.16.xxx.xxx:8110/
username: xxxxx
password: xxxxx
Warning:
If you cannot access the panel,
release the following port (8888|888|80|443|20|21) in the security group
In the VPS:
http://172.16.xxx.xxx:8110/ works but http://187.22.xxx.xxx:8110/ not in both (VM and VPS).
my sudo ufw status is ok
In the VM (bridged network):
http://172.16.xxx.xxx:8110/ works but I would like to use the VM IP (internal network) like 192.168.0.XX and not the router external IP http://187.22.xxx.xxx:8110/ like a VPS server
Related problems:
https://www.aapanel.com/forum/d/4924-docker-from-aapanelaapanel-keeps-restarting
