aaPanel_Jose Change Log: Reconstructing the [aaPanel Terminal] module Adjust the CPU information display format Fix the problem of invalidation of scheduled tasks under Ubuntu Fixed file coverage issue caused by file renaming misoperation under Ubuntu Optimize panel loading logic to increase startup speed by 3 times Optimize data encryption module compatibility Optimize website/database/FTP search function Fixed the problem that the specified directory could not run PHP after opening the directory protection. Fix problems with some machine disks not showing Other detail adjustments
szone aaPanel_Jose CPU Cores are not shown properly. Some raw data is also showing there. Please fix it.
szone Unable to login to SSH from the panel, it is asking for password, when I enter it, it doesn't accept it. All happened after the update.
