aaP_andreaT Hi there, is it just me or PostgreSQL Manager 1.3 is missing English translation? I only see Chinese in the UI. This issue started with the last update, previous version worked fine. Thank you for your work.
aaP_andreaT aaP_andreaT Nevermind, there is no need to backup the existing DBs, they will not be deleted when you uninstall the manager. Thank you for your work, guys.
