if you are using self nameserver like ns1.masterarts.net ns1.masterarts.net then you need to use aapanel dns for this you need to add your vps ip in your domain hosting panel.
if you are using like cloudflare dns then you need need to use internal dns from aapanel just add replace nameservers in your domain panel from with CF nameserver and there you will add your dns records
there is ddns addon on aapanel for CF
just register in Cloudflare its faster dns add CF nameserver to your bigrock panel
