hi when i click restart link in pm2 manager aapanel i got this error
Sorry, something went wrong:
raise NotFound()
File "class/panelPlugin.py", line 1992, in a
return eval(execStr)
File "", line 1, in
File "plugin/pm2/pm2_main.py", line 524, in Restart
if result.find('✓') != -1: return public.returnMsg(True, 'Project [' + get.pname + '] has been restarted!')
AttributeError: 'tuple' object has no attribute 'find'
i try to reinstall pm2 but doesn't work
https://pasteboard.co/Ke1FIzr.png
hi as i said i uninstall and then install it again but still have problem
the installing log doesn't show any problem
Current version: aaPanel LinuxStable 6.8.13 Release time: 2021/07/08
