Changed to su. Got the following;
ubuntu@heringerdigital-staging:~$ C
ubuntu@heringerdigital-staging:~$ sudo su -
root@heringerdigital-staging:~# Last login: Mon Jul 19 14:57:56 2021 from 177.40.128.153
cat: /www/server/panel/BT-Panel: Permission denied
sed: can't read /www/server/panel/BT-Panel: Permission denied
cat: /www/server/panel/BT-Task: Permission denied
sed: can't read /www/server/panel/BT-Task: Permission denied
chmod: cannot access '/www/server/panel/BT-Panel': Permission denied
chmod: cannot access '/www/server/panel/BT-Task': Permission denied
cat: /www/server/panel/data/port.pl: Permission denied
Stopping Bt-Tasks... done
Stopping Bt-Panel... done
Starting Bt-Panel... Bt-Panel (pid 104679) already running
Starting Bt-Tasks... /etc/init.d/bt: line 98: /www/server/panel/logs/task.log: Per mission denied
failed
tail: cannot open '/www/server/panel/logs/task.log' for reading: Permission denied
Command 'Last' not found, did you mean:
command 'last' from deb util-linux (2.34-0.1ubuntu9.1)
command 'ast' from deb jruby (9.1.17.0-3build6)
command 'nast' from deb nast (0.2.0-7build1)
Try: apt install <deb name>
root@heringerdigital-staging:~# ubuntu@heringerdigital-staging:~$ /etc/init.d/bt restart
ubuntu@heringerdigital-staging:~$: command not found
root@heringerdigital-staging:~# /etc/init.d/bt: line 17: cd: /www/server/panel: Permission denied
-bash: /etc/init.d/bt:: No such file or directory
root@heringerdigital-staging:~# cat: /www/server/panel/BT-Panel: Permission denied
Command 'cat:' not found, did you mean:
command 'cat' from deb coreutils (8.30-3ubuntu2)
root@heringerdigital-staging:~# sed: can't read /www/server/panel/BT-Panel: Permission denied
Command 'sed:' not found, did you mean:
command 'sed' from deb sed (4.7-1)
root@heringerdigital-staging:~# chmod: cannot access '/www/server/panel/BT-Panel': Permission denied
Command 'chmod:' not found, did you mean:
command 'chmod' from deb coreutils (8.30-3ubuntu2)
root@heringerdigital-staging:~# chmod: cannot access '/www/server/panel/BT-Task': Permission denied
root@heringerdigital-staging:~# cat: /www/server/panel/data/port.pl: Permission denied
root@heringerdigital-staging:~# Stopping Bt-Tasks... done
Stopping: command not found
root@heringerdigital-staging:~# Stopping Bt-Panel... done
root@heringerdigital-staging:~# Starting Bt-Panel... Bt-Panel (pid 104679) already running
-bash: syntax error near unexpected token `('
root@heringerdigital-staging:~# Starting Bt-Tasks... /etc/init.d/bt: line 98: /www/server/panel/logs /task.log: Per mission denied
Starting: command not found
root@heringerdigital-staging:~# failed
failed: command not found
root@heringerdigital-staging:~# ------------------------------------------------------
------------------------------------------------------: command not found
root@heringerdigital-staging:~# tail: cannot open '/www/server/panel/logs/task.log' for reading: Per mission denied
Command 'tail:' not found, did you mean:
command 'tail' from deb coreutils (8.30-3ubuntu2)
root@heringerdigital-staging:~# Error: BT-Task service startup failed.
Error:: command not found
