tkumarpatna Hello, the load is high. The server command line executes the following command screenshot to see.
yum -y install htop && htop
If a single PHP process takes up a lot of time, there may be a problem with the code
Such as PHP loop
This involves process debugging
The easiest way is to use strace - P to see which PHP file is called
