Hamka
After installing the load balancing in vps1, vps2 and vps3 need to add the same website domain, the A record of the domain name points to the server ip of vps1, and the database connected to the website in the load balancing only needs to be connected to the same database server, otherwise it will cause data inconsistency problem, then you can use the Sync Tool to sync website files.
