aapanel_sniper aaP_tamperplay Hello, the current load status on the front page of aapanel shows the load with reference to the top command of the terminal.
aaP_tamperplay aapanel_sniper If the machine has LDX containerization, will it show the Load Average of the entire node or only the vds itself?
aapanel_power aaP_tamperplay Hello, the load on the surface, showing the overall performance of the server, such as CPU|network|memory|disk IO, belonging to the overall server performance reflected
aapanel_power aaP_tamperplay Hello, first of all I don't quite understand what your vds and ldx are, the information shown on the panel is the information of the server where you installed AAPanel, can you understand it?
aaP_tamperplay Read please https://discuss.linuxcontainers.org/t/lxd-shows-load-avg-of-the-host/9482/2 https://forum.proxmox.com/threads/lxc-containers-shows-hosts-load-average.45724/ This is what I want to know about your panel, since I have an arbitration with hosting
aaP_tamperplay That's not the question!!! The panel shows the resources and load of only the virtual machine from the whole machine or the entire machine completely?
aaPanel_Captain aaP_tamperplay If you are using a container, we have not yet supported the container. In the panel, the load usage on the VPS can be obtained normally
aaP_zmaplex The panel shows the resources and load of only the virtual machine from the whole machine .
aaP_tamperplay aaPanel_Captain The hosting support response about your panel and LDX containerization: ""The link was to the linux forum, where there was an answer to the question why the load average of the entire node is displayed in separate containers. If your developer is not competent enough, let him study the features of LXD." https://discuss.linuxcontainers.org/t/lxd-shows-load-avg-of-the-host/9482
aaPanel_Captain aaP_tamperplay I have replied to you before, and the support for the container is not perfect
