aaPanel_Jose Change Log: Panel SESSION adjustment Centos8.0 compatible optimization Add plugin update instructions Optimize support for python3 Mail server compatible with ubuntu 16+ Other details adjustment
aaPanel_Jose darylfarahi Please try to repair the panel if you still not work press f12 on the browser page and refresh the page. Check if there is an error in this tag
aaPanel_Jose cybertech Can you show me some error messages or screenshots? I tested the installation on centos8 was work.
cybertech aaPanel_Jose install.sh: line 255: python: command not found ================================================= setuptools installation failed.
aaPanel_Jose darylfarahi I tested the upgrade and the newly installed aaPanel was work, can I log in to your panel to check? If you can, please send your login information to my email address zhwyeah@gmail.com
aaPanel_Jose cybertech Are you using this installation command? curl -sSO http://www.aapanel.com/script/new_install_en.sh && bash new_install_en.sh
