aaP_dga_roorkee aaP_usanuman cloudflare origin ssl certificate is showing insecure.... I have used this setting but my cloudflare origin ssl certificate is showing insecure. I am using subdomain for this panel domain... kindly provide help
aaPanel_Kern aaP_dga_roorkee Hello, can you send me the certificate information or file and panel information, if so please send it to kern@aapanel.com,
aaP_kotakomputer.ceo aaP_hprj @aaPanel_Kern: I'm facing similiar issue, the SSL on aaPanel (using Nginx) was updated to CloudFlare, but browser say Let's Encrypt. But I have another server that working fine, this server using Apache.
aaPanel_Kern aaP_tonimarkunya You used the cloudflare proxy. This should be the SSL you set with cloudflare
aaP_tonimarkunya aaPanel_Kern i hec in dashboard cf, the pryx cf is enable , should i disable ? i followwing the instructin by @aaP_usanuman
aaPanel_Kern aaP_tonimarkunya This is not very clear. Currently, it is normal to visit the site without prompting that it is unsafe
aaP_at-rostov Cloudflare SSL installation Add DNS records, enable Proxy status - Proxified. Issue Origin Server certificate. Save Key and Pem. Enable Universal SSL (SSL/TLS > Edge Certificates > Enable Universal SSL). Add domain to aapanel (Website > Add site). Enable SSL for it and add Key and Pem certificate data. Add domain for control panel (Settings > Security > Domain). Change control panel port to 8443. Allow connections in firewall (ufw allow 8443). Enable SSL for control panel (Settings > Security > Panel SSL) and add Key and Pem data. Change control panel IP to your external IP (Settings > Server IP).
aaPanel_Kern Hello, I suggest you check the SSL configuration of cloudflare. The cloudflare certificate only communicates encrypted with cloudflare. The user's browser is set by your SSL in cloudflare aaP_kotakomputer.ceo
aaP_kotakomputer.ceo The UI of successful site has no Key Info (Private and Certifcate CRT/PEM) on Let's Encrypt tab, is it matter?
