aaP_singharun1978 Hello, After 48 hours still my DKIM record not set. Please see snapshot. Please suggest.
aaP_kotakomputer.ceo You need to set DKIM in your DNS. Then click "Refresh domain record". If still did not updated then try to restart your NS Server. Also, to make sure your DKIM setting is correct then checking by: https://mxtoolbox.com/dkim.aspx
aaP_singharun1978 I have updated DKIM in DNS. Please see snapshot. I restarted NS server, still DKIM Record not set, Please suggest, Thanks!
aaP_kotakomputer.ceo Your first post say your domain is amzweb.tk but then your domain in MX Toolbox DKIM Test is: amzaws.tk. Which one is correct? Since "amzaws.tk" result is: "No DKIM Record found", then you must check again your DNS setting. And remember to double check your domain name.
aaP_singharun1978 Oops my mistake! Here is result, it says valid DKIM but aaPanel still shows record not set even I refreshed domain and restarted server many times.
aaP_kotakomputer.ceo Do you use DNS Manager on aaPanel or remote DNS? If you use remote DNS then Uninstall DNS Manager of aaPanel. Also try to access your all NS (usually ns1 and ns2) manually inside your server using nslookup command tool.
aaP_jasonfomenky aaP_kotakomputer.ceo My domain keeps showing the DKIM not set even when Ive already done it in my DNS server
aaP_singharun1978 Got it fixed now! I had to setup DNS inside Digital Ocean droplet rather than domain registrar Freenom.com. Now all set! Thanks for your help.
