KrzysztofMaciejewski Hello, repair panel, key directory permissions will be detected automatically. Key directory default permissions are restored.
This design is for safety.
In addition, it is not recommended to set 777 permissions on the directory, which means that everyone can have read-write execution permissions. This increases the risk of the server being invaded.
If you have to set 777 permissions to the / www / wwwlogs directory, you can execute the following command settings on the server command line
chmod 777 /www/wwwlogs
