@aaPanel_Jose
Error the latest panel 6.8.13
can help CDN was active but error create the website protection with CDN here error
Sorry, something went wrong:
raise NotFound()
File "class/panelPlugin.py", line 1992, in a
return eval(execStr)
File "", line 1, in
File "plugin/fail2ban/fail2ban_main.py", line 625, in set_anti
return self.set_cc_anti(values)
File "plugin/fail2ban/fail2ban_main.py", line 540, in set_cc_anti
result = self.active_cdn(values)
File "plugin/fail2ban/fail2ban_main.py", line 525, in active_cdn
return cf.main(values)
File "/www/server/panel/plugin/fail2ban/cdn/cloudflare.py", line 158, in main
self.set_webserver_log(data)
File "/www/server/panel/plugin/fail2ban/cdn/cloudflare.py", line 79, in set_webserver_log
self.set_apache_log()
TypeError: set_apache_log() missing 1 required positional argument: 'data'
Already update the server
Upgraded:
NetworkManager-1:1.30.0-9.el8_4.x86_64 NetworkManager-libnm-1:1.30.0-9.el8_4.x86_64 NetworkManager-team-1:1.30.0-9.el8_4.x86_64
NetworkManager-tui-1:1.30.0-9.el8_4.x86_64 cmake-3.18.2-11.el8_4.x86_64 cmake-data-3.18.2-11.el8_4.noarch
cmake-filesystem-3.18.2-11.el8_4.x86_64 cmake-rpm-macros-3.18.2-11.el8_4.noarch epel-release-8-11.el8.noarch
firewalld-0.8.2-7.el8_4.noarch firewalld-filesystem-0.8.2-7.el8_4.noarch kernel-headers-4.18.0-305.7.1.el8_4.x86_64
kernel-tools-4.18.0-305.7.1.el8_4.x86_64 kernel-tools-libs-4.18.0-305.7.1.el8_4.x86_64 kexec-tools-2.0.20-46.el8_4.1.x86_64
libsss_autofs-2.4.0-9.el8_4.1.x86_64 libsss_certmap-2.4.0-9.el8_4.1.x86_64 libsss_idmap-2.4.0-9.el8_4.1.x86_64
libsss_nss_idmap-2.4.0-9.el8_4.1.x86_64 libsss_sudo-2.4.0-9.el8_4.1.x86_64 libxml2-2.9.7-9.el8_4.2.x86_64
libxml2-devel-2.9.7-9.el8_4.2.x86_64 lz4-libs-1.8.3-3.el8_4.x86_64 openldap-2.4.46-17.el8_4.x86_64
python3-firewall-0.8.2-7.el8_4.noarch python3-libxml2-2.9.7-9.el8_4.2.x86_64 python3-perf-4.18.0-305.7.1.el8_4.x86_64
python3-rpm-4.14.3-14.el8_4.x86_64 python3-syspurpose-1.28.13-3.el8_4.x86_64 rpm-4.14.3-14.el8_4.x86_64
rpm-build-libs-4.14.3-14.el8_4.x86_64 rpm-libs-4.14.3-14.el8_4.x86_64 rpm-plugin-selinux-4.14.3-14.el8_4.x86_64
rpm-plugin-systemd-inhibit-4.14.3-14.el8_4.x86_64 rsyslog-8.1911.0-7.el8_4.2.x86_64 sssd-client-2.4.0-9.el8_4.1.x86_64
sssd-common-2.4.0-9.el8_4.1.x86_64 sssd-kcm-2.4.0-9.el8_4.1.x86_64 sssd-nfs-idmap-2.4.0-9.el8_4.1.x86_64
systemd-239-45.el8_4.1.x86_64 systemd-libs-239-45.el8_4.1.x86_64 systemd-pam-239-45.el8_4.1.x86_64
systemd-udev-239-45.el8_4.1.x86_64 tuned-2.15.0-2.el8_4.1.noarch unzip-6.0-45.el8_4.x86_64
Installed:
kernel-4.18.0-305.7.1.el8_4.x86_64 kernel-core-4.18.0-305.7.1.el8_4.x86_64 kernel-devel-4.18.0-305.7.1.el8_4.x86_64
kernel-modules-4.18.0-305.7.1.el8_4.x86_64
Removed:
kernel-4.18.0-240.10.1.el8_3.x86_64 kernel-core-4.18.0-240.10.1.el8_3.x86_64 kernel-devel-4.18.0-240.10.1.el8_3.x86_64
kernel-modules-4.18.0-240.10.1.el8_3.x86_64
can help how to solve / fix this ?
want to use CDN for website protection at File2Ban > Manager
using Apache installed
