aaPanel_Jose Change Log: Load status tab adds detailed load information Optimize homepage loading efficiency Fix the prompt error that the recycle bin is closed and then opened Terminal adjusted from string to binary transmission Fix the issue that some machines will not automatically clean up the panel backup Optimize the directory browsing interface Fix the problem that composer executes the command error Optimize the homepage UI
szone aaPanel_Jose No error message is there. The login button does respond to my request. However I am able to login with VPN now!
huynhduckhoan When I clean install and upgrade to beta, I can not access to xterm, and I back to stable I can enter password and login to xterm. But after that, I upgrade to beta and I still can not access xterm. Please check 🙂))
