• Support
  • renewing ssl certificate vs redirections
Hi,
I noticed when I set up a new site that if I enabled the domain.com redirection to www.domain.com I was not able to create the certificate. I understand the reason and I find it normal šŸ™‚
My question is: once the certificates are generated, if I set up this redirection, will it block when I renew the certificates?
Thanks
    Raffi Hey, brother, I’m not sure if your operation will affect your SSL certificate renewal. It is recommended that you use DNS verification, so that there will be less interference from redirection, reverse proxy, and CDN.
    Connect with us: šŸ“Ø Telegram šŸ’¬ Discord Email: support@aapanel.com
