Hi Support,
I was trying to enable SSL for the aapanel using the Letsencrypt option but i was getting a error popup without any message and it goes away.
Screenshot is attached.
When i looked at the log "/www/server/panel/logs/error.log", I can see the below error.
[2021-03-18 12:15:07,814] ERROR in app: Exception on /config [POST]
raise NotFound()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/_compat.py", line 39, in reraise
raise value
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functionsrule.endpoint
File "/www/server/panel/BTPanel/init.py", line 613, in config
return publicObject(config.config(),defs,None,pdata)
File "/www/server/panel/BTPanel/init.py", line 1439, in publicObject
return run_exec().run(toObject,defs,get)
File "/www/server/panel/BTPanel/init.py", line 1386, in run
result = eval(fun)
File "<string>", line 1, in <module>
File "class/config.py", line 705, in SetPanelSSL
sps = sp.set_lets(get)
File "class/setPanelLets.py", line 200, in set_lets
self.copy_cert(domain_cert)
File "class/setPanelLets.py", line 166, in copy_cert
self.__read_site_cert(domain_cert)
File "class/setPanelLets.py", line 96, in read_site_cert
key_file = "{path}{domain}/{key}".format(path=self.vhost_cert_path,domain=domain_cert["subject"],key="privkey.pem")
TypeError: 'NoneType' object is not subscriptable
Please help
