Michaelduong If possible, you can always fix the Memcached Extension PHP 7.4 error on Raspberry Pi 4 + Ubuntu Server 20.04. Error status cannot install this Extension on PHP 7x versions ... Thanks!
Mars Will you update the docker image too on dockerhub? That one is still using an older version. and can you supply the dockerfile too in your github repository? thanx for all your work!
JAY still the problem is not fixed switching from nginx or apache to OLS sites geting 404 error and while accessing websites tab Internal Server Error
haxi The error with "ddns" is that if you add an "A" record, the same hostname is created twice incloudflare.
