Hello, brother, does not exist powertest.
How to add subdomain in aapanel
edgar2031 ‘Powertest’ is an example directory for our staff and can be ignored. You need to select which directory your subdomain is bound to.
I did not get that
edgar2031 If you have a website, its current domain name is: aapanel.com. You want to add a subdomain name: bt.aapanel.com to a certain directory under this website, right?
If this is the case, just follow the operation described by'aapanel_power' and add it in the screenshot.
edgar2031
Morning sir,I checked and found that your subdomain was not resolved. It needs to be resolved by the domain controller to your server before it can be used.
and how can I solve that problem?
edgar2031 It needs to be resolved by the domain controller to your server before it can be used.
For example, go to dns.com (or your domain registrar) to resolve football.randpages.com to 38.201.190.219.
HI sir, I am having a problem as well with subdomain. on my first subdomain, I created a subdomain where the main domain DNS is pointing to cloudfare. and cloudfare pointing to my VPS.
maindomain works well, but when I create a subdomain, I try both created new FTP and subdirectory to Main DOmain, the subdomain always show the domain site.
I added new site but then, subdomain shows the 3rd website I added.
in the image:
- is new website -domain.net
- is the subdomain of 3rd website.---advertise.domain.link
- is the first domain ----domain.link
any solution to this? thank you
Hi, I resolve my problem slightly, I bought the domain in hostinger and pointed the domain to cloudfare, and I disable subdomain by disabling CNAME Subdomain Cloudfare proxy. my problem now is how to protect the subdomain back to cloudfare? if I enable DNS proxy it will redirect my site to maindomain that recently added as I said before. is there alternative to point Domain the otherway?
aapanel_power ok when you do that then how will setup the ssl because he show the default template of aapanel (congratulations the website is now online )
