aaPanel_Jose
please try it if you want to see the problem for yourself
try to open your panel using the cellphone .... !!!
1.Select the file you want to edit, then please edit.
2.When the text editor appears, try editing your file (source code) in the editor or clicking your text. (suddenly enlarged)
3.Then see, if you can see the save button?
can this be fixed the problem?
