Today I go to the panel to create an FTP account using the port defined by me 7123 and it does not work. It shows the error: "ERR_CONNECTION_REFUSED". I enter the SSH console, log in as ROOT and type the command service bt start - nothing happens. Same: service bt stop, service bt restart. When I enter just bt, the panel configuration menu does not appear. When I type bt 16, port 7123 appears. The one I'm using. What may be the problem? Websites, MySQL databases, SSL certificates and FTP server are working fine.
Panel not working (on web and ssh)
hello, Execute the following command in ssh to see if the bt file is normal. At the same time, do you say that executing bt 16 directly displays the port? Can you take a screenshot?
